Home > Maintenance & Mods (L322) > 2009 Vogue Steering wheel mod
Benjerbustmills
United Kingdom 2012 Range Rover HSE TDV8 Stornoway Grey
Morning guys n galls
I’ve just managed to get hold of a new Walnut steering wheel, with matching parchment leather for my 322.
I think it’s going to look really lovely.
Now, one question.
Will the illuminated steering wheel cluster switches from the 10/12 fit and work accordingly?
Size wise I cannot see an issue, because all the steering wheels from 02-12 are the same size, it’s more of a compatibility issue.
Also, while I am at it, I intend to replace the door lining armrest lights, that are on the way out.
Has anyone got any experience of doing this?
Finally, I am fed up of buying “so called faultless “ LED lights for the interior, for them to fail fairly shortly afterwards.
Specifically the footwell puddles, and tailgate.
Is there anyone out there that produces a decent LED retrofit bulb??
Thanks in advance
Si
L322 TDV8 VOGUE
TD4 Hippo 3 door
Ford 2.0 TDCI Kuga
Does anyone want a superb example of a 550bhp 03 Paramount XJR?? 80K miles, well maintained, & faaaaaaaaaasssssstttt
Post #610131 23rd Oct 2021 10:05am
tb10
England 2005 Range Rover Vogue 4.4 V8 Tonga Green
Hi Si,
The later airbag won’t work if your car was fitted with the original version.
Re the LED’s, a topical and common problem. The only ones that continue to work on mine are the puddle lights. The others make the interior look like a cheap discotheque Laughing
Regards
John
Post #610134 23rd Oct 2021 10:52am
Benjerbustmills
Hi John
Really appreciate your input.
I’m not intending on using another airbag, I’m just trying to ascertain whether the illuminated switch modules, that are separate from the airbag will be compatible.
To be honest, you can pick them up for £30 , so it might be a trial and error exercise.
With regard to the LED’s, I have zero intention of turning my beautiful RR into a mobile pimp me up disco car, with colour changing LED’s!!
Si
Post #610182 23rd Oct 2021 6:35pm
mjdronfield
You will need to use all the airbag and switches from your current wheel.
Just use the bare new wheel… transfer all your electronics on to it from your current wheel.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #610183 23rd Oct 2021 6:42pm
Benjerbustmills
Thanks for that!
I was probably aware that it wasn’t possible to use the newer switch modules, but you never know until you’ve tried.
I’ll console myself that the new wheel is absolutely fabulous.
I’m on the lookout for a 11/12 Westminster or SC.
Many thanks for your kind input.
Si
Post #610184 23rd Oct 2021 6:58pm
