Home > Maintenance & Mods (L322) > Malfunctions
A.Pires
Portugal 2002 Range Rover Vogue Td6 Zambezi Silver
Malfunctions
After some works on the steering special in the electronic box to replace the magnet on the solenoid there are strange things happening like:
1 - the key in the ignition switch wont turn at first, I have to remove it and insert it again to turn;
2 - when I insert and turn the key, the steering movement wont happens as before. Only with the lever on the steering wheel;
3 - the radio wont work. When I turn the ignition switch, apears the LR logo on the screen but if I press the button wont work;
4 - the AC fan starts to work but the AC isn't switched on.
I didn't start the engine because the starter motor is of to replace it.
What can I have done wrong?
Cheers
Post #609705 19th Oct 2021 12:00pm
Pfazz
2019 Range Rover Autobiography SDV8 Loire Blue
Unrelated faults such as that can often point to battery problems. Agueroooooooooo. 93-20
I swear you will never see anything like this ever again....watch it..drink it in.
Post #609724 19th Oct 2021 3:36pm
A.Pires
Probably due to the starter is off and no connections to the system?
Post #609730 19th Oct 2021 4:22pm
get that engine started before trying to diagnos anything.. ... - .- -.
Post #609734 19th Oct 2021 5:35pm
