![]() | Home > Technical (L322) > fuel presure problem |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1271 ![]() ![]() ![]() |
Was it doing it before you serviced it? |
pablo Member Since: 03 Oct 2021 Location: kildare Posts: 20 ![]() ![]() ![]() |
yes it was,when i got the dpf cleaned the guy said there was a fuel pressure problem that kept coming up on the computer but would not show any codes |
when the car is running right i swear to god its like a ferrari the power is unreal but this fault is getting on my nerves. |
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 ![]() ![]() ![]() |
Have a look at the four short rubber hoses that are connected into the intake plenum (large plastic doughnut shaped box, located under the engine cover) and see if there's any soot/oil/or splits/cracks, etc. They are a common weak spot on the 4.4 TDV8 engine and will set off the Restricted Performance problems, often at random but more usually under hard acceleration.
yes there is a black sootat the back right hand side rubber a bit like a diesel leak could that be it? |
Check the hose to see if there's a split.
ill post photos tomorrow,thanks very much for your help. |
Got the car sorted at last.......
That's excellent news Pablo |
