![]() | Home > Maintenance & Mods (L322) > Fault code U2101-56 (2f) |
tj196443 Member Since: 08 Oct 2018 Location: Newcastle Posts: 173 ![]() ![]() ![]() |
That seems strange that it says it’s not fitted, have you tried changing it to fitted in the CCF on the gap tool to see if that makes a difference. |
Tomc Member Since: 15 Oct 2020 Location: Belfast Posts: 37 ![]() ![]() ![]() |
Thanks for your reply.
Very easy to do, if you go to the page that states it not fitted the option should be there to change to fitted, it will ask you to confirm and then it will change it to fitted. Sometimes it comes up that the operation has failed but that is misleading as it usually does carry out the operation successfully. It’s been awhile since I’ve changed anything in the CCF files but if you give the gap manual a quick read it will show you how. Good luck and hope you get it resolved. |
