Home > Technical (L322) > Help - What is this telling me? |
umitbat Member Since: 06 Jan 2010 Location: Space Posts: 433 |
I once solved this by disconnecting sensor,contact clean,and battery disconnection.
12th Oct 2021 8:03pm |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1192 |
Try changing the height up and down a few times, then...... if still faulty
12th Oct 2021 8:04pm |
Yossarian Member Since: 07 Mar 2011 Location: Wales Posts: 66 |
...thanks guys i'll take a look.
13th Oct 2021 11:15am |
tj196443 Member Since: 08 Oct 2018 Location: Newcastle Posts: 170 |
Hi, I’ve just had the same issue on the rear offside sensor, the gap IID diagnosed it as the sensor being faulty. Changed the sensor and then calibrated the suspension and the problem was solved. Can be a pain getting the two torx screws out as they tend to weld themselves into the bracket and sensor. Mines a 2020 model but I think earlier cars have the rear sensor connected using hex or 4mm Allen heads. I also think you have to check if you have cvd as it’s a different sensor, you can tell if it’s CVD if it has a cyclinder at the bottom of the suspension arm. Hope this helps. |
13th Oct 2021 3:22pm |
thank you, that helps a lot 2010 5.0 Supercharged AB Stornoway Grey/Ivory
13th Oct 2021 5:30pm |
Meant to say mines a 2010 model and not 2020 ! Is the car dropping to the bump stops when left parked and then automatically rises to normal height when you start the engine ? That’s what mine was doing until I changed the sensor. |
13th Oct 2021 8:09pm |
Mine seems to lower the front more than the back overnight but neither front or back is dropped, just lowered from 'Normal' height. It seems to me the ECU is trying to level the car to where it thinks the rear sensor is at Access height. As soon as car is started it lifts right back up and looks and measures near as damn it the same on each corner... drives perfectly normal too. Will let me change to all three height settings as well. I only think it's the N/S/R sensor at fault because the 4*4 info diagram in the infotainment is showing the N/S/R sensor as at the lower limit of its range of movement when it's physically in Standard or Off-road heights. It only stops flashing when the car is physically lowered to Access and that makes me think when the whole car is lowered to Access that N/S/R sensor aligns back up with the other three so stops flashing.
14th Oct 2021 1:25pm |
Definitely sounds like a duff sensor, does the fault clear on the dash when you clear it with the IiD tool and then come straight back up in a second ? Mine did that also, I sprayed a ton of penetrating fluid on the screws holding the sensor to the bracket, I think it may even be possible to remove the bracket at the top and then attempt to remove the 2 bolts. I just stuck with getting the bolts out which was a pain, hopefully yours will come straight out and then it’s a two minutes job ! |
14th Oct 2021 2:26pm |
UPDATE:
30th Oct 2021 1:08pm |
