Home > Technical (L405) > Lane departure via CCF?
ajac8
I have the hard button on the right knee switch pack (looks like a car diagonal across a pair of vertical dashed lines) but it does nothing so far as I can see. Nothing also shows via the instrument pack relating to lane keep or assist.
Not sure what I would have the button which does nothing. There is a plug connector attached behind.
Does anyone know if land departure warning (or even land keep assist) is a dealer configured item via CCF?
2013 AB.
Cheers Thumbs Up 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #608892 11th Oct 2021 9:25pm
TJH1985
It can certainly be turned on / off by CCF but you need to have the correct camera fitted as well. The same camera also provides the traffic sign recognition which IMO is the better feature of the two.
Some info here: https://www.gap-diagnostic.com/avada_faq/r...e-warning/
Do you have deployable side steps? Someone might have been lazy and used the wrong switch pack when they were fitted. Sold - Bell a 2015 MY16 Loire Blue Autobiography 4.4 SDV8
Previously George a 2007 MY07 Java Black VSE 3.6 TDV8
Previously a 04 MY04 Defender 90 Sad
Post #608906 12th Oct 2021 5:49am
ajac8
Thank you - I suspect you are right - I assumed the function used the surround cameras.
I do have deployable steps but was thrown by the fact that a plug is in the back of the switch pack.
I'll speak to Gap.
Tanks again.
93 RR Classic efi
Gone in order:
03 L322 Oslo Blue
98 P38 Rioja Red
Post #608913 12th Oct 2021 7:42am
