Home > In Car Electronics (L322) > Sat nav
Springer
United Kingdom 2003 Range Rover Vogue Td6 Galway Green
Sat nav
Hi all will a Mrk4 BMW DVD Satnav work in the later RR with the touch screen ?
Thanks Peter
 2003 TD6
Post #608766 10th Oct 2021 7:35am
Highroller
United Kingdom 2005 Range Rover Vogue SE 4.4 V8 Java Black
Easy to swap & worth a try , Obviously check the connections before you disconnect. Thumbs Up
Post #608768 10th Oct 2021 7:51am
Ansi
Switzerland 2010 Range Rover Autobiography 5.0 SC V8 Adriatic Blue
Don't think so, as far as I know the touch screen system is a different brand, I belive its Ford.
Post #608779 10th Oct 2021 9:08am
No.
Post #608784 10th Oct 2021 9:32am
nemmi69
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Barolo Black
On that note. Is there a late Ford unit that will fit? What doesn't kill you is just bidding it's time.
Post #612519 13th Nov 2021 5:56pm
