Home > Technical (L322) > Brembo pad retention pins |
Mike220 Member Since: 21 Sep 2020 Location: uk Posts: 116 |
Yes I feel your pain, I was there myself earlier in the year. An air chisel with a pointed tip also works if you have one, the number of impacts per minute/second is unmatched and felt far kinda to the caliper body than hammer and punch blows
9th Oct 2021 10:21pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8192 |
A common problem, I always take the pads out, clean it all up and regrease the pins during routine servicing, keeps them free... Pete
9th Oct 2021 10:22pm |
Happydaze Member Since: 30 Aug 2021 Location: Wirral Posts: 70 |
Yeah, stupid design!
10th Oct 2021 5:22pm |
Caesium Member Since: 21 Sep 2021 Location: Essex Posts: 451 |
This is the grease I use. This is the grease you’re supposed to use on an alloy calliper.
10th Oct 2021 6:36pm |
