Home > Maintenance & Mods (L322) > Rear hub/knuckle question
Ben84
England 2005 Range Rover Vogue Td6 Tonga Green
Hi,
I've had my rear hub rose joint bushes changed yesterday,
but have been advised that the knuckles are worn so the bushes
are a sloppy fit.
My question is are all the rear hub knuckles the same on all the L322 model ranges?
I have a 2005 td6 but would I be able to fit a knuckle/hub from a 2010 4.4 for instance??
Any help much appreciated.
Thanks
Post #607930 2nd Oct 2021 12:20pm
Merchy
May be worth talking to one of the site sponsors, plus the advanced factors site has some handy drawings showing part numbers for various models, that may help you, a quick look shows similarities, Thumbs Up
Post #607943 2nd Oct 2021 4:32pm
Pawl
I've never heard of a worn knuckle causing new bushes to be loose & they are all the same !
The bushes are static in the knuckle - a reasonably fit that will not change as the inside of the bush wears.
Far more likely is that some very cheap aftermarket bushes are not made to the correct dimensions & therefore are a loose fit.
I'd be asking the garage what make the bushes were. Paul,
2006 FFRR TDV8 Vogue 151,000 miles & now sold
Post #607945 2nd Oct 2021 4:35pm
Classic888
Apparently the following applies
RLH000082/92. 2002-2009
LR39924/25. 2010-2012. Chassis number. AA000001 onwards.
This is model year change not date of registration.
Post #607948 2nd Oct 2021 4:50pm
Ben84
Thanks for all the advise, the garage will removing
the aftermarket bushes and fitting genuine bushes on Monday.
We will see if they make a difference?
Post #607968 2nd Oct 2021 7:42pm
tb10
England 2005 Range Rover Vogue 4.4 V8 Tonga Green
I did mine a few weeks ago…. And then did them again the day after, this time using genuine parts, as the first attempt by using non-genuine rose joints ended up with them moving as Ben84 describes. I thought the first attempt went in too easily…… Shocked
Post #607989 3rd Oct 2021 12:08am
Merchy
Before fitting new ones to my new front knuckles, I put the new ball joints in the freezer over night. They were still a good interference fit and took a while to bolt them in, but made fitting slightly easier.
Post #608042 3rd Oct 2021 2:14pm
Ben84
Fingers crossed the genuine bushes will sort my
problem.
The garage had quoted me a price and obviously
tried to make themselves even more profit by using cheaper
aftermarket bushes. Censored
Post #608054 3rd Oct 2021 3:52pm
wayneg
Having recently done this job on My TD6 I cannot see how the new bush if correct can be loose in the hub carrier. They are a press fit needing a serious bush press to get them out and back in and are retained with a meaty circlip. Any wear on the old bushes would not affect the carrier bore as it would be inside the outer sleeve.
See my thread.. https://www.fullfatrr.com/forum/topic59083...hub+bushes 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #608444 6th Oct 2021 10:47am
Ben84
Genuine bushes have now been fitted.
Problem solved Thumbs Up
Post #608446 6th Oct 2021 11:19am
Result... Thumbs Up Pete
Post #608468 6th Oct 2021 2:09pm
