Home > Technical (L322) > HELP not sure what my Range Rover is but have an issue |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7803 |
Yes, all the cars your shape 2002 to 2012 is the L322. That’s the code used by the factory. The current shape is the L405.
16th Sep 2021 2:16pm |
dennij Member Since: 23 Feb 2019 Location: Up North Posts: 450 |
Servicing is a good point as it could be something simple as an old fuel filter restricting flow 2011 TDV8 Vogue SE |
16th Sep 2021 2:47pm |
Denise Pinky Member Since: 16 Sep 2021 Location: Co Durham Posts: 34 |
full service a couple of months ago with HiQ, they didn't mention a code just said the fault didn't occur when they drove it. My son is a mechanic and has cleaned this out for me as it happened a couple of months ago too, he checked it 2 weeks ago and it still looked clear - see pictures in my gallery.
16th Sep 2021 3:46pm |
Here are the pics… save folk clicking about….
16th Sep 2021 4:40pm |
thanks, I'm new to this so didn't have a clue |
16th Sep 2021 5:34pm |
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 329 |
I have a spare set of MAF and MAP sensors to sell cheaply if anyone wants them! |
16th Sep 2021 10:45pm |
I’ll ask my son, how much you wanting 😊👍 |
16th Sep 2021 11:30pm |
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 688 |
Pinky......I don't wish to appear rude, sarcastic or even patronising but the words Range Rover & HiQ really do not go together.
17th Sep 2021 6:32am |
He doesn’t work for them 🤣
20th Sep 2021 10:06pm |
Had to change the side fuel pump when I had my TD6. Easy enough to do. Some have got them going in an emergency by giving it a whack, but sounds like yours is a bit intermittent. Worth changing.
21st Sep 2021 7:34am |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3811 |
As anyone who knows me or reads my post will know - I'm no mechanic However, I did have similar symptoms on a Mercedes diesel (it would run but had no power) it was nothing more complicated than a split turbo hose. I only know this because I asked the Merc garage I took it to, needless to say the charge for the fix and the actual cost of the fix were miles apart. It's not just Range Rover garages Geoff |
21st Sep 2021 7:57am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8245 |
IMHO Fox889 is bang on... I'm sorry but if you can't afford a specialist to work on your car then buy a different car or learn to do it yourself.
21st Sep 2021 10:22am |
Mjdronfield - thanks for the advice, the pump sounds rough so hopefully it is just that.
21st Sep 2021 3:39pm |
jim4244 Member Since: 31 May 2012 Location: UK Posts: 853 |
Hi Denise
21st Sep 2021 3:57pm |
