Home > General > TDV8 Gearboxes
Johnte
TDV8 Gearboxes
Does the gearbox on the TDV8 have the same life expectancy as the TD6 gearbox ? or are they different / upgraded / modified ?
Thanks Thumbs Up
Post #65958 26th May 2011 9:43pm
mzplcg
Different box. 6 speed instead of 5. ZF unit I believe.
Post #65960 26th May 2011 9:56pm
dan_uk_1984
Yup, the 6 speed belongs to the same family as the 5 speed ZF box, almost identical infact, although slightly longer to incorporate the extra gear. Obviously a different valve block and software.
With an oil service interval of 60,000 miles.
Post #65964 26th May 2011 10:21pm
stu
United Kingdom 2012 Range Rover Vogue TDV8 Orkney Grey
if i am not mistaken the TD6 box is a GM box which is not as good as the ZF box, hence all the issues.
they were troublesome in the X5 too. Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #66024 27th May 2011 12:01pm
Correct
Post #66026 27th May 2011 12:08pm
SteveMFr
Site Sponsor
Correct except for the 'not as good part'. The ZF has it's flaws as well - %wise maybe a little less than the GM, but the GM box is smoother.
(pre Jag-motor V8 owners insert rebuttals here)
Yes it is. Drive both back to back.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #66033 27th May 2011 12:25pm
Mackie Automatic Transmissions in Glasgow who service mine and appear to know more than most on these transmissions say there really is not allot between the GM and ZF "boxes" even with regular servicing its a case of when and not if , in both cases they weren't designed to haul around the weight of a Range Rover.
the ZF six speed has proved to be better but that's all "better but not perfect" if the control unit goes its time for a new "box" because its mounted internally and apparently rebuilds are less strait forward
Mind you this is all what one business has told me and not documented fact. 2008 MY Supercharged
Post #66046 27th May 2011 2:09pm
33CHINACARS
Australia 2017 Range Rover Autobiography SDV8 Santorini Black
TD6 Auto was a GM 5L40E. As others have said TDv8 is ZF
Post #66047 27th May 2011 2:09pm
stu
if my FF had a new gearbox module last year before i bought it, does that mean it will have had the gearbox replaced???
i think i may have to get onto LR customer services, they should have an answer. Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #66066 27th May 2011 5:39pm
BigJ
United Kingdom 2005 Range Rover Vogue 4.4 V8 Stornoway Grey
The ZF6HP box is alot different to the older ZF 5 speeder fitted in our Strangies and most BMW's.
The 6 speed box is of better design (Of which you would hope for in a later box).
It's the only part of my Range Rover I hate in all honesty.... Though tough wood still silky smooth. It will fail one day without warning tho. Used to have:
2005 FFRR 4.4 Vogue - BRC LPG Conversion & Remapped
Now have:
2008 SSRR 3.6 TDV8 - HSE and plenty of toys
Post #66084 27th May 2011 9:13pm
