Home > Maintenance & Mods (L322) > LED Front Wing Side Indicator Bulbs
mjdronfield
As I’ve just put LED bulbs in my full beam halogen units,
https://www.fullfatrr.com/forum/topic59406-15.html
thought I’d look to change the side indicator bulbs. They don’t match the rest of the indicators on the 2010 onwards models, as all the other indicators are LED. I bought the below. No issues, not too bright, same as original bulbs and the orange light matches too. You can still see them from wide viewing angles, plus the end of the bulb isn’t orange, so you don’t get the egg yolk look that the originals have.
No errors or anything….
https://www.ebay.co.uk/itm/353409669358
 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #608737 9th Oct 2021 5:29pm
Excellent, nice to get a recommendation with so many choices... Thumbs Up Pete
-Click here for Thread-
Post #608740 9th Oct 2021 5:36pm
mjdronfield
They were from a more recognised brand name, and less than a tenner so thought I’d give them a go.
These do need to go in the right way round/with the right polarity though, so if it doesn’t work, turn it through 180 degrees and put the bulb back in the holder….
And if you are fitting to a model with orange lenses on the car, you will need a white bulb, not an orange one.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #608745 9th Oct 2021 6:05pm
