Home > Maintenance & Mods (L322) > Battery low warning - Brand new AGM battery
Caesium
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
So I'm cleaning the car and within 10 mins I am getting a LOW BATTERY - START CAR warning.
I thought my battery was dying so I went an got a brand new one, coded it in with IID and it's still doing it!
Any ideas what could be causing this?
Worth mentioning that it was also doing it yesterday when the car was connected to a stabilised 13.5v power supply too.
the old battery is 12.5v so nowhere near dead.
Post #607222 24th Sep 2021 3:57pm
scuddriver
United Kingdom 2011 Range Rover Vogue 4.4 V8 Java Black
MY 2011 TDV8 does the same. It appears to be a bug in the battery monitor, which was addressed with a software update. I haven't had mine done because I don't use the Stealers any more, so I just put up with it.
Like you, when I first got the car, I replaced what was probably a perfectly good battery! 2011 Vogue TDV8 4.4
1992 Mazda Mx5
Post #607233 24th Sep 2021 4:37pm
Dolphinboy
me too. constantly throws up start engine warning but battery is 12.3 V!!
Post #607234 24th Sep 2021 4:56pm
Caesium
I’ve got IID so I’ll look into the update and see if I can do it.
Post #607236 24th Sep 2021 5:01pm
DrRob
I think it’s normal to be honest Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #607238 24th Sep 2021 5:26pm
Baltic Blue
I don’t want to sound like a M.D. , but they all do that… Rolling with laughter
Post #607250 24th Sep 2021 7:27pm
mm289
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Ipanema Sand
Which I reckon is most of the problem with the fbh not working properly, it keeps getting told the battery is to low
I did wonder what the correct battery code is to use in IID but no one seems to know Sad
MM 2011 TDV8 AB
2006 TD6 AB (Gone to Wales)
Post #607252 24th Sep 2021 8:30pm
