![]() | Home > Technical (L405) > Rotary gear selector not popping up. |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1394 ![]() ![]() ![]() |
Mine was replaced under warranty when it stopped moving freely, and squeaking, so maybe replacing the unit is "the fix"? Only Range Rovers since 1988 |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35492 ![]() ![]() |
sounds like the solenoid is failing..you will probably need a new rotary gear selector module.. ... - .- -.
Hammer Member Since: 14 Oct 2012 Location: Perth Posts: 123 ![]() ![]() ![]() |
Thank you Gents
Okay it’s arrived from UK to Perth Western Australia, takes four days to get here sits at airport arrivals for another four days.
Thanks Stan, but it’s actually entire module I need to replace. 2015 AB 5.0 Supercharged
When mine was replaced the console was removed. Be careful not to scratch the lower glovebox leather in the process. My dealer did that, confessed and replaced it too. Only Range Rovers since 1988 |
Thanks
