Home > Maintenance & Mods (L322) > Witter R32B Towbar On a 2012 westie
crowebeard
United Kingdom 2012 Range Rover Westminster 4.4 V8 Orkney Grey
Evening all,
I've just fitted a Witter towbar to the new Westie and while it all went together after a bit of effort, I've ended up with the rear silencer approx 40mm lower than the original non-towbar fitting.
The same Witter towbar is fitted to my 2004 and this has the silencer almost touching the heat shield (albeit with the different fixings), but although the silencer on the new one is fitted as per the instructions using the original brackets, it's not quite sitting correctly.
Before I go drilling new holes in the towbar support to move the exhaust hanger bracket up, could anyone else with a Witter R32B on a 2010-2012 have a quick check please and see if the hanger bracket is attached as mine is in the photo below? Although they don't show up very clearly in the photo, the 2 upper corners of the hanger are crimped and sit in the upper hole and outside the end of the towbar support, to presumably stop it rotating.
Many thanks David
2012 Range Rover Westminster 4.4TDV8
2004 Range Rover Vogue 4.4 V8 (LPG) (Not quite gone)
2021 Mazda CX-5
2003 Porsche Boxster
Post #605871 7th Sep 2021 8:56pm
