Home > Maintenance & Mods (L322) > Black smoke and stuttering TD6
Boydonegood
United Kingdom 2004 Range Rover Vogue Td6 Ipanema Sand
Hi all.
Have had a fuel issue where if I Rev over 3200 (kick down) it throws up an error and starts struggling to pull itself along and rattles.
Not end of the world as I’ve learnt to drive without exceeding that and has been fine for months. (Even if it does play up I can clear it in seconds with Icarsoft).
Noticed yesterday it seams to be stuttering around 2200rpm and throwing out loads of thick black smoke.
Sounds like turbo is still kicking in and under 2200rpm it drives fine.
Ticks over fine
And in park it will rev up to 3500+ with no stuttering and no smoke.
It’s only when under load.
Any ideas?
Vacuum maybe?
Thanks in advance Accept, some days your the pigeon, some days your the statue!
Post #605184 30th Aug 2021 2:24pm
mjdronfield
Black smoke is normally a split hose or collapsed hose….. sometimes hard to find as they may only show under load….
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #605187 30th Aug 2021 2:53pm
Boydonegood
Oh really?
Fingers crossed it’s something that easy.
Will have a proper look tomorow after work. Vacuum hose or something more substantial?
I replaced the vacuum ones under the manifold when I changed seals on fuel pump a few month ago. I wasn’t comfortable then that they were as big as the ones I took off. But we’re “get me outta trouble Halfords” stuff Accept, some days your the pigeon, some days your the statue!
Post #605189 30th Aug 2021 2:58pm
Mr Tee
Maybe injector related too.
Post #605192 30th Aug 2021 3:26pm
Jimrs2k
Id say most likly injectors, for how long it takes pull them out and most likely find one or two need the nozles cleaning etc.
Post #605368 1st Sep 2021 9:38pm
Boydonegood
Only just got around to looking at car today.
Clearly viseable 60mm hose N/S/F not connected. New jubilee clip and no more smoke and power back,,,
Thank you so much guys
Tel Accept, some days your the pigeon, some days your the statue!
Post #606812 19th Sep 2021 3:51pm
berkshirelad
United Kingdom 2007 Range Rover Vogue SE TDV8 Tonga Green
Black smoke from a diesel is usually a sign of over fuelling; blue is oil burning and white…well you don’t want to know what white means.
Post #607076 22nd Sep 2021 4:53pm
