Home > Technical (L322) > Restricted Performance / P0483-27 / P0483-37 - fixed error |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 |
The air charge temperature you would expect to be higher than ambient, the turbo's have compressed it, the intercooler will take some of the heat out but it obviously cant get it below ambient.
28th Aug 2021 3:19pm |
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 329 |
"Refer to the electrical circuit diagrams and check connections are secure and wiring integrity"
28th Aug 2021 5:53pm |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1751 |
A fan circuit fault will cause R.P faults
28th Aug 2021 6:07pm |
Hojdica Member Since: 04 Oct 2020 Location: Leighton Buzzard Posts: 6 |
Hi all,
28th Aug 2021 10:26pm |
That is normal
29th Aug 2021 6:06am |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2475 |
As Mikey has noted, the problem is with the cooling fan circuit, nothing to do with intake air-flow. If the cooling fan isn't known to be working as required then performance is restricted trying to avoid damaging the engine from overheating. |
29th Aug 2021 7:47am |
Managed to get to the bottom of this.
6th Sep 2021 9:28pm |
