Home > Technical (L405) > Detachable towbar
aguiness
United Kingdom 2017 Range Rover Vogue SE TDV6 Aruba
Detachable towbar
Hi all
I have had a detachable towbar fitted
But when I put the car in reverse I don’t get the guide line option for the tow hitch
How is this enabled or is it only for the electrically deployable ones
Post #604889 26th Aug 2021 9:32pm
James W
Saudi Arabia 2017 Range Rover Autobiography SDV8 Siberian Silver
Interested to see the answer to this as I think my FFRR should have Tow Assist too but I've not been able to get it to 'appear' - My electrics work for towing (fitted by a third party) but I think I need a dealer-enabling thing as my PDC sensors also don't disable when reversing - it knows a trailer is attached but still gives a constant beep which is annoying (especially when the mute button just makes it a bit quieter!) FFRR SDV8 Autobiography
Post #604912 27th Aug 2021 8:22am
spbee
tow bar assist would need to be turned on in the car config file using a suitable diagnostic tool, there is also a setting for tow bar fitted
Post #604932 27th Aug 2021 11:49am
DavidB64
United Kingdom 2019 Range Rover SVAutobiography 5.0 SC V8 Barolo Black
When I had my 3rd party detachable tow bar fitted had to have Tow Assist enabled by the local dealers. I now get the the hitch line and camera zoom function when you change the camera settings - makes hitching up less stressful and not starting our holidays with an argument with the trouble and strife Smile you also get the revering lines if you put your trailer details in and add the reversing target Smile
Post #605759 6th Sep 2021 6:31pm
