Home > Technical (L322) > Engine System Fault after split intercooler hose
rich89
United Kingdom 2010 Range Rover Autobiography 5.0 SC V8 Causeway Grey
Hi All,
After 5 months of trouble free motoring (2006 3.6 TDV8 Vogue) I had the engine system fault pop up with limited performance.
Turned out the top right hand intercooler hose had a split in it.
I replaced it and all was good for a week or so (Very few miles driven).
I was on my way home this morning and it popped up again. Checked the hose and its seated correctly and not split again so i'm unsure why it's done it again.
My cheapy little code reader displayed this:
P123B
Barometric Pressure - Turbocharger/supercharger boost correlation sensor B.
Me not knowing anything about turbos/boost, has anyone has this before?
(I tried to clear the code but it did not clear)
Thanks
Post #604077 18th Aug 2021 11:19am
if that hose went it might be that another is on the way out.. ... - .- -.
Post #604087 18th Aug 2021 12:41pm
rich89
I'll go and check the others later.
Post #604093 18th Aug 2021 1:48pm
William97841
If your getting black smoke it might be the inlet manifold check for cracks normally along the top seam. Hope it helps.
Post #604423 22nd Aug 2021 7:57am
