Home > Maintenance & Mods (L322) > Rust prevention underneath
mrblonde
United Kingdom 2003 Range Rover Vogue Td6 Adriatic Blue
2003 TD6, only covers about 1k-2k miles a year. Noticed surface rust on some of the subframe while under it recently, was planning a bit of preventative maintenance. Was going to wire brush off what I can and paint it with something, it hammerite still the best? Or anything else I should use?
I’m not planning on stripping it down to every nut and bolt, just coat the parts I can reach easily with it in off road height while it’s dry outside
Any recommendations gentlemen please?
Post #603615 12th Aug 2021 4:16pm
i'd be tempted to use this stuff..paints straight on to the rusty bits and you'd probably wont have to wire brush it..
[other anti rust paints are available] ... - .- -.
Post #603616 12th Aug 2021 4:29pm
ur20v
A Trap
Deleted
Post #603617 12th Aug 2021 4:34pm
Merchy
As in above post Thumbs Up
Just to add, unless you have almost no rust to start with, then surface preparation is a must, the better the prep the longer the protective coating will work. ALL loose rust / dirt / grease / oils etc should always be removed as part of the prep.
Post #603628 12th Aug 2021 6:01pm
Range Rover L322
Just had mine done with Fertan and then Raptor, which was recommended to me by one the bigger names in the 4x4 racing world.
Raptor is widely used in the USA - I think on all the GMC vehicles , is inexpensive, easy to apply and very hard wearing. Also it can be touched up later easily. I am told this will last for 10 years.
Post #603629 12th Aug 2021 6:02pm
paul271
Scotland 2002 Range Rover Vogue Td6 Epsom Green
Raptor is sturdy stuff as long as the corrosion underneath it isn't still spreading as you'll not notice it until its eaten away the steel beneath the coating.
Crackin stuff if the prep is right though. 👍
Post #604208 19th Aug 2021 6:03pm
TJH1985
As a X Defender owner, I second everything above its all down to the prep, especially if you are using some of the more permanent solutions as you’d never spot the rust creep until it’s too late.
I now personally prefer good prep, a few light coats of CIO from Buzzweld and then an annual coating of Lanoguard as it makes it really easy to inspect, and touch up / correct and looks OEM.
That being said I used some EM121 Epoxy Mastic on the arches of the L322 and after 5 years I chipped a few bits off and it was pristine underneath.
The L405 has a generous coating of Lanoguard on it and that’s all and it looks like this:
 Sold - Bell a 2015 MY16 Loire Blue Autobiography 4.4 SDV8
Previously George a 2007 MY07 Java Black VSE 3.6 TDV8
Previously a 04 MY04 Defender 90 Sad
Post #604216 19th Aug 2021 7:22pm
