Home > Maintenance & Mods (L322) > wheel alignment
klj
United Kingdom 2011 Range Rover Vogue 4.4 V8 Stornoway Grey
wheel alignment
Hi all,advice / info needed.
Had my wheels aligned a few months back, all ok within tolerances.
Today , following a tip from an ancient LR tech, I took measurements front to back / centre wheel to wheel rim datum. Car on level ground , steering dead straight, standard suspension height setting.
I discovered that the rear offside wheel was seemingly 10mm further back than the back wheel (nearside pair).
I am told that the LR tolerance is 5mm or less. Odd. So I looked at my alignment report, it doesn't report this end to end dimension , just all the relevant cambers. I cant recall the kit but it wasn't Hunter. Is it ever checked?
Question. Can the rear upper and lower arms be adjusted fore and or aft, if so that has to be doen before camber settings?
Cheers
Ken ----------------
2010 RR tdv8 3.6 ( gone but not forgotten ...)
2012 RR tdv8 4.4
2004 RR 4.4 V8 (M62) -gone but not forgotten (sob)
1998 P38 RR - least said the better
2009 BMW 7 Series 3.0d
Various motor cycles - BMW GS
1998 Jag XKr 4.0 V8
Post #603483 11th Aug 2021 2:00pm
