Home > Technical (L405) > Front climate/cd module removal
funnyguy1
United States
So in my quest to repair the slide door that covers the drink holders on the center console, the only post I was able to find was Fleagle from about 2013 where he had the same problem, so he removed the entire console and was able to correct the spring. I was wondering, if it wasn't difficult, to take out the front climate control panel as the back of the the tray assembly might be accessible to repair the spring? Has anyone removed the front climate control panel? Is it difficult?? Thx in advance!
Post #603112 7th Aug 2021 4:08pm
knwatkins
Yes, it's very easy. I've taken mine out to replace the climate controls.
From memory, you need to pop off the leather surround from the screen, pop off the two aluminium side panels, then it's two screws to undo.
I'm not sure if it'll give you access to what you need though. Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #603119 7th Aug 2021 5:01pm
funnyguy1
United States
Me either but would rather start there than removing the
Entire console. I was hoping that with the climate control panel out I might be able
To see the spring mechanism for the slider door that goes over the drink holders. Thanks again for your input!
Post #603666 13th Aug 2021 1:00am
