Home > Maintenance & Mods (L322) > 3.6 TDV8 Alternator - is this connector broken???
Pestle
United Kingdom 2009 Range Rover Vogue SE TDV8 Java Black
After an absolute stinker of a job, I've fallen at the final hurdle (before the inevitable hell of reassembly...).
Is this connector on the rear of the alternator broken? I can't remove it for the life of me, and after five hours, I'm at my wit's end.
Post #603106 7th Aug 2021 2:22pm
chris_read
England 2009 Range Rover Vogue TDV8 Stornoway Grey
Believe me; you haven’t fallen at the first hurdle. To get to this point you’ve done a good job, as you must’ve removed the fan and probably removed the various bolts holding the alternator in place.
It is a pig of a job, of that there is no doubt. I spent a long time on mine during the week after Christmas, when the temperature was not much above freezing, so you should be glad that your fingers aren’t numb from the cold while you do this.
From memory it needs some squeezing to release the connector, but as I did it without being able to see it, I can’t offer much more info.
Keep going; it will be worth it. Once you disconnect it, the next hurdle will involve the plastic intake below, which needs moving slightly to help you remove the alternator once you rotate it. Someone recently advised me to slacken off a couple of 8mm bolts to give more clearance but I can’t vouch for that, although I wish I’d known about the at the time….
Hopefully you are following the guide in the Wiki, which I couldn’t have done without.
Keep us updated Thumbs Up 2017 Jaguar F Pace 25t Portfolio - still part of the JLR family 😀
2009 3.6 V8 (MY2010) - my first ever diesel! - now also gone Sad
2004 4.4 V8 Petrol Vogue - now gone
Post #603116 7th Aug 2021 4:47pm
Pestle
Thank you! I've actually already managed to get the body of the alternator free (somehow), so at least I don't have that particular thing to dread, although getting the new one in will no doubt be equally horrid.
My concern is that there doesn't seem to be anything to squeeze or press on the connector - where the two orange rubber nibs are on each side, it looks like there may be some plastic missing, but I can't be sure.
Does anybody know where the wire leads to? It would be handy to get some more slack, so I'm not in a stress position while doing yoga to actually reach the bloody thing.
I'm also rather wary about breaking the wires - what are the implications if that happens? Would it need an auto electrician to come out to fix it?
Post #603124 7th Aug 2021 5:27pm
When I changed mine (twice), I had this issue, it takes strong fingers and a good amount of perseverance to get this connector off.
There is a write up on here on this, to which I contributed to, so have a search for it.
Good luck Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #603175 8th Aug 2021 9:18am
Pestle
Thanks for the replies everyone - much appreciated.
I did some digging last night and found a place that sells replacement connectors, so I could actually visualise what I needed to do. Two minutes' work this morning, and the old alternator is off!
Putting the new one in will give me something to look forward to in the evenings this week, I'm sure...
Post #603228 8th Aug 2021 7:28pm
TDV8 Paul
I remember struggling with this ridiculous clip, took me bloody ages to get it off, I had to go away and have a cup of tea and come back to it again and still struggle with it, but eventually it came free, it’s simply perseverance I’m afraid, and sore fingers 😂 2009 (2010 MY) 5.0 Supercharged Autobiography
2007 TDV8 Vogue SE
2005 BMW E63 645ci
2024 Porsche Macan
Post #603369 10th Aug 2021 12:19pm
