Home > Technical (L322) > 4.2 SC Misfire help please |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3110 |
I’d start with the easiest thing first, swap the coils from cylinders 2 and 4 with another 2 cylinders and see if the misfire follows the coils.
21st Jun 2021 11:12pm |
Dode4444 Member Since: 18 Jan 2021 Location: Buckie Posts: 43 |
Car has done almost 150k miles…..
21st Jun 2021 11:13pm |
Yea, it’s not too bad.
21st Jun 2021 11:17pm |
Just watching a video on it just now like you say looks pretty easy so thank you…..
21st Jun 2021 11:24pm |
Cylinder 1 is the front offside, 2 is the front nearside.
21st Jun 2021 11:45pm |
Thank you 2005 (55) Range Rover 4.2 Supercharged Vogue SE Java Black |
21st Jun 2021 11:47pm |
Mikebob Member Since: 10 Jun 2019 Location: Pretoria Posts: 10 |
Check your fuel pressure as well |
22nd Jun 2021 5:04am |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2215 |
Check the little boost pipe between sc and fuel pressure sensor Current stable:
22nd Jun 2021 8:23pm |
Still trying to find out the reason for this misfire and have came across this plug and can’t see where it would go.
4th Aug 2021 2:11pm |
Is it the plug from the fuel pressure sensor? Whip the engine cover off four but it’s on the right if you’d rant on front of it with a boost pipe going to it Current stable:
4th Aug 2021 7:30pm |
Hi,
5th Aug 2021 12:09pm |
Mine is in bits at the moment so I’ll have a look tomorrow and see if I can find your plug. It doesn’t look familiar though I’m afraid.
5th Aug 2021 9:10pm |
Thanks very much,
5th Aug 2021 9:15pm |
Just to be sure, that’s a grey 2 pin plug? What colour are the wires going into it? If you follow the wires back, where do they leave the main loom? 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
5th Aug 2021 9:30pm |
