Home > Technical (L405) > Bike Rack
supershuttle
Bike Rack
I didn't know whether to post this here, or in the caravanning bit for the experts there to have a look at. I have always taken the view that by putting bikes on a rack (4) that sits on the towbar (deployable) I needn't worry about nose weights. However someone (with a lesser car) has suggested that it might not be the case and I should worry. I only occasionally take 4 bikes but the all up weight may be as much as 200lbs (assuming all e-bikes) - should I worry after all its a bike rack not a caravan. I have looked at the manual but am easily confused Confused Geoff
Post #602688 3rd Aug 2021 3:34pm
JamesD
United Kingdom 2016 Range Rover Vogue TDV6 Corris Grey
I don't think you need to worry about nose weight at the carrier is entirely fixed on the tow ball and there is no trailer, you only need to worry about nose weight from a heavy trailer or caravan that is forcing the towbar down and would mean you have to adjust the balance point of that trailer/caravan. 2021 L405 Vogue D300
2016 L405 Vogue 3.0TDV6 (Sold)
Post #602711 3rd Aug 2021 7:38pm
JamesD
Actually I stand corrected there are nose weight limits, in the EU its 150kgs or outside the EU is 200kg (deployable), the manual says towbar accessories are limited to 66.8Kgs (I have no idea why that number is lower than the nose weight of a trailer)? 2021 L405 Vogue D300
Post #602712 3rd Aug 2021 7:45pm
Some info on here -
https://www.fullfatrr.com/forum/topic59792.html
Post #602714 3rd Aug 2021 7:54pm
supershuttle
it seems I am OK at a mere 200lbs on the rack, assuming the rack itself weighs 20lbs. If it were 200kg I might have to watch it. Geoff
Post #602735 3rd Aug 2021 8:53pm
