Home > Technical (L322) > Curious AC fault
Thunderbird2
Australia 2007 Range Rover Vogue TDV8 Buckingham Blue
Curious AC fault
Hi all
After years of wanting, I have taken the plunge into FFRR ownership. Managed to pick up a very tidy '07 3.6 Vogue which has enjoyed transmission oil changes every 60,000km (37k miles) and a brand new engine 70,000km ago.
She's been pampered her whole life..... buuuuuut, it's a Range Rover, and there's no way I'd get away with faultless performance!
I've noticed an issue with the air conditioning. I have read the forums here and on other sites, but can't find anything which quite matches my symptoms.
I do not fully understand the AC's principles of operation, so I'd appreciate suggestions as to the root cause, as well as to what other tests I should carry out to narrow down the possibilities.
THE FAULT: Around 4 minutes after start up, the blower will begin to cycle between 'off' and the original blower speed. It will continue to cycle, with the 'higher' fan speed getting lower and lower each cycle until the blower simply stays off.
OTHER OBSERVATIONS:
    - The air con will operate normally from start up, and respond correctly to all user inputs across a full temperature range during this time. Adjusting the temperature while in 'Auto' produces the expected changes in blower speed
    - The 'MAX' function works fine
    - The air produced by the system is nice and cold
    - Each on/off cycle takes about 2 seconds
    - The rear AC panel works fine and its operation does not appear to impact or being impacted by the fault in the front
    - The fault presents itself irrespective of whether the engine is hot or cold
    - The fault clears when the engine is shut down and the key removed: restarting (even within a few minutes) appears to clear the fault
My working hypothesis is "something funky and electrical", since the normal operation followed by a staged shutdown seems stranger than what you might expect from a component which has just straight up failed. Partial failure of a blower motor? Resistor pack?
All input welcome.
Thanks all
Will 2007 FFRR Vogue 3.6 TDV8 (Buckingham Blue)
1979 Jaguar XJ12 5.3 LWB (Juniper Green)
Post #602650 3rd Aug 2021 10:08am
DrRob
I'd start with changing the Final Stage Resistor (aka Hedgehog) for a new one. Don't buy a cheap one.
Easy to swap out iirc on majority of cars.
Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #602652 3rd Aug 2021 10:15am
mjdronfield
+1 for the above. They do fail from time to time and would be my first port of call. Tends to cause erratic blower speeds..... would it cause all the symptoms you have... not sure, but I would definitely remove it from the equation first.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #602665 3rd Aug 2021 12:44pm
Thunderbird2
Thanks guys, looks like I'm going hedgehog shopping.
Will update this thread with results. 2007 FFRR Vogue 3.6 TDV8 (Buckingham Blue)
Post #602768 4th Aug 2021 8:54am
Merchy
Noted, yours is a 2007, so hope this may help, see the below for changing the hedgehog. Not a huge job, just a pain working in the foot well.
https://www.rswsolutions.com/index.php/mki...e-resistor
Post #602789 4th Aug 2021 10:52am
Thunderbird2
Hi everyone
By way of update, changing out the FSR seems to have cured the fault.
While I was in there I found the original FSR still in place but disconnected, and a second FSR wired in but hanging from the steering column by a cable tie Rolling Eyes . Both were genuine parts, made in Germany: makes me wonder if the second failed because it overheated, being outside the AC duct, or whether the blower motor is on the fritz and is killing FSRs.
Oh well- time will tell! The new one is installed (properly) in time for the Australian summer.
Merchy- that link was a great help. As you say, not complex, just a little fiddly. Having worked on 70s and 80s Jags, I'm used to sticking my hand in confined spaces, closing my eyes, and letting my fingers figure out what's going on!
Have a great one, all
Post #605377 1st Sep 2021 11:57pm
Cool... Very Happy Pete
Post #605380 2nd Sep 2021 7:25am
