Home > Maintenance & Mods (L322) > SEAT CUSHION VALANCE - fixing? |
paul_h_8 Member Since: 09 Jun 2010 Location: North East - England Posts: 256 |
I also need to know how to do this
21st May 2011 10:55am |
It's a bit of a "mare" to do, but just fiddly. Move the seat all the way forwards and up before you disconnect the multiplug otherwise you'll never get it off. |
21st May 2011 10:57am |
Ask member daveo think he got his seat re-done …..
21st May 2011 10:58am |
nick h Member Since: 26 Jan 2011 Location: notts Posts: 782 |
thanks does it just lever/pull off? |
21st May 2011 11:06am |
No, there are a few torx screws in there, you'll think you've got them all, but there will be a couple you'll miss. I missed the one at the back.
21st May 2011 11:13am |
Yes and no , once you have undone the screw at the back you need to carefully work your way around releasing all the clips and the seat control panel from the trim. If you are replacing a cracked trim then I guess its not so bad to brake a few because like Dan said " it's a bit of a mare " other wise some of the bigger clips at the bottom can be very stubborn . 2008 MY Supercharged Rimini Red / Jet four zone climate remote park heater and no ugly kid windows. magnus satis quod turpis satis |
21st May 2011 11:15am |
thanks |
21st May 2011 11:32am |
M44K TS Member Since: 09 Feb 2010 Location: North East U.K. Posts: 1325 |
The clips can be quite fragile as I found when I removed my old ones. If I remember rightly, refitting them, hook them on at the front first then clip them into place. Make sure the lumbar adjustment switch is clicked all the way in, it's a when it pops out and you have to remove and refit a 2nd time. 2006 Mercedes CLS
7th Jun 2011 6:57pm |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
theres a screw at the back, you can see this fixing, then you want to unclip the trim at the front, i found if you push the trim into the seat at the front and pull out the part that curves around the front it will unclip, then there are 2 clips under the trim, you can see these if you get down and look under the seat, with your finger just pull down on them gently and it will release.
7th Jun 2011 7:47pm |
stevenA Member Since: 23 Jan 2011 Location: Paris, France Posts: 34 |
At the risk of stating the obvious, and repeating what has already been said, if you are replacing the part, getting it off is not the issue - but make sure that the all the clips of the new part are perfectly aligned before committing, as if you engage the top clips and the rest is not aligned, releasing them without breaking them, is ...... |
7th Jun 2011 8:49pm |
