![]() | Home > In Car Electronics (L322) > My “How to” on fitting a Halo Pro front and rear dash ca |
Furnitureman Member Since: 26 Jan 2021 Location: Leicestershire Posts: 351 ![]() ![]() ![]() |
Well I can confirm it works a treat. Got to take your time but I’m chuffed to bits with it, it makes hitching up a doddle, the pictures make the tow ball look like it’s next to the bumper but there is a gap of four inches so enough to play with
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35633 ![]() ![]() |
good job Craig, makes hitching up easier.. |
It does Stan especially when moving over from a D3 where if you over run the hitch hits the massive towing eye, no such protection on the Full Fat 2012 Range Rover Westminster 4.4 TDV8
Ajmngn Member Since: 25 May 2021 Location: Gloucestershire Posts: 194 ![]() ![]() ![]() |
What an innovative solution to the towbar view - great job! Is there any lag between car moving and seeing on screen? Even if yes, I’m sure it’s easily overcome with a little-by-little approach when reversing on. I’m just curious. Also, did you test the towbar view with the camera mounted high on the rear window, which would be my preferred location? If it can’t see the towbar then I totally see the logic for mounting lower down, unless that was your personal preference anyway. Andy
I don’t think if it’s mounted high up it will see the towbar, as for lag there is a tiny amount but if you take your time it’s fine 2012 Range Rover Westminster 4.4 TDV8
RosesGabor Member Since: 28 Feb 2024 Location: South Yorkshire Posts: 4 ![]() ![]() ![]() |
Hi, did you use the Road Angel wiring kit? I cannot work out where best to place both red and yellow wires. I have even asked them (useless) looks like it may be an auto electrician job. |
