Home > Off Topic - Other Cars > 2008 Vauxhall Corsa Not Starting.... any ideas?
mjdronfield
Are there any folk on here with Vauxhall knowledge?
Admittedly I’ve not seen the car... my nephew who is 17 has a 2008 Corsa and he can’t get it to start. Was fine last weekend he said. He’s posted this on a Vauxhall forum, but got no replies.... any thoughts? Doesn’t sound right to me....
So I have a 2008 1.4 corsa sxi. It's my first car and I took it for it's MOT on 28/06/21. That morning it wouldn't start, the dashboard lights would turn on but the engine wouldn't start. I had it towed to the garage and they couldn't start it either even after trying to jump-start it. They told me the battery is flat and have replaced it. After replacing the battery the engine still won't start and after trying both sets of keys they've told me I need to send it to vauxhall for them to reprogram it. I'm being told by multiple people that this isn't normal and basically doesn't happen so is there anything I can do to sort it myself without needing it reprogramming? Also please let me know if anyone has had a similar issue. Thank you  2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #599271 30th Jun 2021 7:00pm
mjdronfield
Seems it’s sorted now..... one way or the other 🤣
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #599272 30th Jun 2021 7:10pm
In the old days:
1. Does the engine turn over (battery) ?
2. Is there fuel?
3. Is there a spark? .
Post #599283 30th Jun 2021 7:58pm
mjdronfield
Cheers. I think his Dad will just let Vauxhall fix it. I’ve said they need to use a garage that doesn’t make things worse.
I don’t think even a Rangie needs to be reprogrammed if the battery goes flat 😱
Don’t get why they didn’t just charge it up, guess they must have tested it... who knows....
See what happens medium term.... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #599287 30th Jun 2021 8:13pm
AJGalaxy2012
Check the drains on the scuttle area, the ECU is mounted at the nearside there and can get flooded (did the none start happen after heavy rain?). Cheap fix, ebay, buy an ECU and keys kit circa £50 ish, replace ecu and key transponder, job done.
Me and my boy have bought 6 or 7 Corsa's in this state, fixed them as per the above and moved them on for a very tidy profit. BMW i3 Electric Car
2006 VW Touareg 3.0 TDi V6
Post #599290 30th Jun 2021 8:24pm
mjdronfield
Ah, ok. Nice one. I will let him know.
Cheers
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #599297 30th Jun 2021 9:33pm
