Home > Technical (L405) > How to stop wing mirrors auto folding?
mikemike39
I have a FF 2016MY Vogue - bought secondhand a couple of years ago. It's fantastic, of course
The issue I have is that it came with the wing mirrors set up to fold in when the vehicle was locked and out when it was unlocked
I don't really mind that, although I never park anywhere where that would be an issue
Last time out one of them didn't unfold on start up
I managed to manually fold them both in and then out, it came out OK then.
But I don't really want to push my luck - it's quite tricky driving it with one mirror locked in, and of course if the motor packed up it would cost $$ to fix
The manual says your retailer can set it up as it is currently set up - and presumably they can reverse the process
I don't really want to go to a dealer,
Anyone know how to disable that feature?
Many thanks, Mike
Post #599178 29th Jun 2021 8:36pm
The dealer, or anyone with the correct equipment to rewrite the CCF (car configuration file) can do it.
Well that's the L322 I expect the L405 is the same... Thumbs Up Pete
Post #599181 29th Jun 2021 8:50pm
jettec
Australia 2013 Range Rover Autobiography TDV8 Fuji White
Go into your dash menu with the steering wheel switches look up car settings and you will find a listing for mirror auto fold function push disable option.
Very easy that should do the trick.
Post #599215 30th Jun 2021 6:56am
