Home > Technical (L322) > 4.4 TDV8 Oil Consumption
RR2B
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Baltic Blue
Apologies if this has been discussed before, but what is a 'normal' oil consumption for the TDV8? Mine has dropped two divisions (however much that is) on the display scale over approx 1,000m of mixed driving. Reasonable or excessive? Thanks 2011MY 4.4TDV8 Autobiography Baltic Blue
TVR Griffith
Alfa Romeo Mito QV
Post #599123 29th Jun 2021 2:23pm
DrRob
Seems a bit much. I think 1 notch is 150mL Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #599140 29th Jun 2021 5:28pm
4040
United Kingdom 2012 Range Rover Westminster TDV8 Santorini Black
Re: 4.4 TDV8 Oil Consumption
Mine drops a couple in about six months, approx 2500 miles. Though I do a lot of 6 mile trips to work and perhaps cancelled DPF regens fill it up a bit with diesel ? Not sure
Post #599188 29th Jun 2021 9:12pm
4434Morrison
United Kingdom 2012 Range Rover Vogue SE TDV8 Santorini Black
Mine uses no oil whatsoever between 6k oil changes. Typical use is around town 3 mile trips to and from office Monday to Friday - An occasional 100 to 20 mile trip every other weekend or so and every 3 months a round trip of 3k miles to the UK from Eastern Europe, which includes high speed runs through Germany on the way to and from the UK. 2012 4.4 TDV8 Vogue SE Current
2015 E220 with AMG Sport Pack - Currently driven by my son
2010 3.6 TDV8 Vogue - Written off by my son
Post #599209 30th Jun 2021 5:38am
diesel Dave
Have you checked for leaks? It’s not unheard of but unusual for them to burn oil. Check around the oil cooler in the V of the engine, also less likely the oil pump has been known to leak from a large plug located on the top of the pump itself, The pump bolts on the front of the engine and is driven directly if the crank.
If all dry and you keep using oil, taking it the oil has been changed recently you may need further investigation to ensure you don’t have a turbo seal beginning to fail.
Good luck Thumbs Up
Post #599211 30th Jun 2021 6:14am
DrRob
I had all 3 = oil leak bingo Rolling with laughter
* Oil cooler
* Oil pump "plug"
* Secondary turbo replaced
Welcome to the L322 ownership experience Big Cry Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #599219 30th Jun 2021 7:11am
RR2B
Thanks to all for the advice. I think I have to be more methodical with my checks, as the level is up a notch today. I’ll ensure exact same level position and timing after engine off for future checks.
No evidence of leaks around the oil cooler, bell housing or chassis members, no oil in coolant that I can see, and no smoke on acceleration. 2011MY 4.4TDV8 Autobiography Baltic Blue
TVR Griffith
Alfa Romeo Mito QV
Post #599249 30th Jun 2021 2:23pm
