Home > Maintenance & Mods (L405) > Oil level inicator SDV8 engine -how precise it is?
Wojtek
Poland 2014 Range Rover Vogue SE SDV8 Luxor
Hello
After a few S class MB i have L 405 SDV8, c.50t miles, the level oil indicator showing once full level, nex time two mark less (the same condition -few hours after ride in my garage). I know, that guitar string is better to check the oil leve; Thank You for Your opinions.
Post #599757 6th Jul 2021 7:24am
CS
My experience was that it was very sensitive to whether the car was on perfect level ground or at an angle, and as it measures in whole segments rather than being infinitely variable one did tend to get quite different readings. Only Range Rovers since 1988
Post #599777 6th Jul 2021 10:25am
Baltic Blue
The readings are also very oil temperature sensitive.
If you refill with cold oil, then expect the oil level readings to go up by a full segment as it reaches normal running temperature.
Post #599786 6th Jul 2021 11:47am
Wojtek
Thank You very much, right, I also noticed that ground level is sensitive factor,probably also the temperature. I am affraid of rising the oil level (DPF) , i never saw indicator on my dashboard (red or orange), that dpf process is running. Maybe there is no such thing.
Post #599800 6th Jul 2021 2:17pm
