Home > Maintenance & Mods (L322) > window screen repair
letsavit2
United Kingdom 2004 Range Rover Vogue Td6 Java Black
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...K:MEWNX:IT
just used this and it only bloody worked..was surprised. Laughing ...tiny little mark left on a chip i had. 2004 black Vogue TD6
Post #63149 9th May 2011 3:26pm
is it the same stuff as the windscreen company's use? ... - .- -.
Post #63153 9th May 2011 3:32pm
letsavit2
dont really know mate, its just a resin with a little tool to inject it into the chip.
Thought for a tenner ill give it go and was pleasantly surprised when it worked. 2004 black Vogue TD6
Post #63159 9th May 2011 3:50pm
i had my mondeo windscreen done and seemed to put resin into the crack and used some sort of suction/pressure type apparatus to make sure the resin was pushed into the crack, this was done free under my insurance.. but for a tenner and the convenience of doing when you want , thats not to bad.. ... - .- -.
Post #63175 9th May 2011 5:08pm
Just had the windscreen replaced on my wife's car as there was so many repairs it looked bad and we are selling it. I've always had my apprehensions about the replacement of a screen, that it's never right afterwards but the fitter was brilliant, he knew his stuff and took his time and did a great job. Only cost £60 excess too. Discovery 4 HSE
Post #63196 9th May 2011 6:24pm
piersie
England 2003 Range Rover Vogue Td6 Epsom Green
Alas a replacement screen is only as good as the fitter putting it in. I had one replaced on my new Shogun and from then on was plagued by wind noise. I had it taken out three times and refitted but was never the same. Last year had a screen fitted to my Mondeo ST and it was excellant, the fitter really new his onions. Thumbs Up
Post #63292 10th May 2011 11:07am
letsavit2
yea i'm dubious with regards to screen replacement, especially when there heated. 2004 black Vogue TD6
Post #63305 10th May 2011 4:03pm
Reformed
Think I might give this a go, as I called Autoglass yesterday and was told they don't work with my insurer so they advised me to phone them. I call my insurer, she says I will get one of our local approved repairers to call you then 10 mins later the same guy from Autoglass rings back wanting to book it in!
I know its me being silly now but I said to the guy you can't make your mind up as to to if you will or won't work with my insurer so how can a trust the quality of your work. Reformed
Post #63563 12th May 2011 10:05am
its probably only red tape in the sense that autoglass need authorisation from your insurer before they say yes..
Post #63581 12th May 2011 11:50am
letsavit2
the cheap ebay kit worked for me, although still the very slightest mark left.
i might of got lucky though so if your insurance is sending a pro at no cost to you then i would go for that. 2004 black Vogue TD6
Post #63663 12th May 2011 7:14pm
VINILCC
USED THE SAME KIT ON MY V8 VOGUE WITH GOOD RESULTS
Post #64384 17th May 2011 8:31pm
Re: USED THE SAME KIT ON MY V8 VOGUE WITH GOOD RESULTS
welcome new member...
just a heads up, you're posting in the subject box with capitals, you need to post in the 'big box' below with lower caps.. Wink
Post #64457 18th May 2011 7:29am
