![]() | Home > Technical (L322) > Adaptive Dynamics Fault |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8533 ![]() ![]() ![]() |
I take it you have cleared the fault and it has returned..? Pete
Sandman77 Member Since: 26 May 2021 Location: Glasgow Posts: 33 ![]() ![]() |
Yes, it always returns. |
My guess would be a cheap pattern sensor or a new faulty one...!!
I’ll bring up the live values of all 4 sensors and see if there is any discrepancies and report my findings. |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2648 ![]() ![]() |
The height sensors on these vehicles are 2 height sensors in 1. If the height sensor isn't for a vehicle with adaptive dynamics then it won't have the 2nd output. Live suspension heights mean nothing as the L322 height signals aren't used by the adaptive dynamics module.
It’s definitely the right type of sensor because the fault only came on a few days after I got the car.
The fault code and description is proof that the sensor or the wiring to it is faulty. As the 2 rear sensors are the same, either swap left and right sensors to see if the fault swaps sides which would prove that the sensor is faulty or buy a new sensor. Electromechanical devices such as the height sensors are generally reliable but an electronic component can fail after only a short while. |
Thanks for the tip, I hadn’t realised that the left and right sensors can be swapped side to side.
Can you hammer in a T27...??
I do have a T27 so will try hammering it in tomorrow night (already cleaned all the crud from my eyes and hair tonight). |
So I tried a T27 bit but there was no way it was going to fit. Nor could I find anything else that might help and there is not enough room to get anything to grip it. I’m going to book it in with my local mechanic. I also noticed a clicking noise from the front left wheel while turning right so I think it may be a cv joint needing replaced too.
klj Member Since: 24 Aug 2019 Location: Frozen North Posts: 66 ![]() ![]() ![]() |
You are on the right track. My issues started with the three amigoes and notchy gear changes. Started by looking at sensors - but turned out to be rotten hub ends where reluctor rings fit. Got some good ones from a breakers and few months back and re cycled oe sensors. B---ds to get out, loads of Plus Gas and gentle efforts to remove. I found that very gentle side to side twisting ( not pulling) eventually pursuaded them to come out. I fitted Delphi ones at first but nfg. ----------------
meant to say - Dremeled the torx heads off first - ebemn if you get them out the actusl sensor is very unlikely to surrender. They get rusted in tight. Terrible design imo. Loads if garages dont use the grease packs properly and that really help too |
Just to close this off. I finally got round to taking the car to my local mechanic who replaced the rear sensor for (I had bought a genuine replacement). The fault hasn’t returned so it looks like it was just a dodgy sensor after all. I was only charged £45 labour for the job. Wish I went straight there rather than mess about for hours trying to remove a rounded off bolt myself. |
