![]() | Home > Technical (L405) > L405 4.4 2013 - huge coolant leak - diagram |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35653 ![]() ![]() |
theres a workshop manual download link in the wiki.. ... - .- -.
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 774 ![]() ![]() ![]() |
Common problem on the 4.4. Kev
albertocsoares Member Since: 28 Nov 2012 Location: Brazil Posts: 15 ![]() ![]() |
Thank Stan, I checked all the files on the L405 2013 - (Work Manual) and did not find the Cooling Diagram, have you ever seen it on the documentation? Thank you! |
AnotherMutley Member Since: 16 Jan 2017 Location: Kent Posts: 400 ![]() ![]() |
It’s definitely there, looked at it recently, there’s everything, capacity, testing procedures and diagrams. |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16339 ![]() ![]() ![]() |
Quite common on a 4.4 sir |
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1318 ![]() ![]() |
PM me 2018 SE SDV8 4.4 Byron Blue |
I will change the oil cooler gasket today and pray it solves, if not my mechanic wants do pull the engine down as he does not have access to work between the engine and the car panel, what do you think about his plan? |
PM sent, thank you! |
Thank you, I found it now using my computer, had a bad time yesterday looking for the files on my phone. |
Glad you found it. |
Changed the oil cooler gasket, but the problem was not there, the mechanic says it may be the EGR valve, what do you guys think?
I know this is a bit like closing the stable door after the horse has bolted but have you pressure tested the coolant system to see where the leak is coming from? Coolant leaks can be a pain in the .... to find, there is a UV additive on the market that you put in the system to aid diagnosis. Normally on the 4.4, its either the Thermostat housing, Oil Cooler o-rings or one of the pipes. |
Yes we did the pressure test, it came from the right back top of the engine, going down to the top of the starter. We drained the system and pumped smoke on it but unfortunately it did not work. We are now taking the EGR out to see if we find anything there. Thank you all for the help! |
EGR is a PITA on the 4.4... I hope you get it sorted sir... |
