Home > Maintenance & Mods (L322) > Light cluster water woes |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8119 |
I used to get that in my fatty off roader after wading, I drilled a very small hole in the bottom to let it drain out...
17th May 2021 6:14pm |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3127 |
there is lots on this forum ref this. do a search. Mine had a slight leak in the top right, invisible to to see with the eye. sealed with glue and dried out.
17th May 2021 11:47pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16248 |
As above, drill a small hidden hole to let the water out then reseal the whole light and refit.. |
18th May 2021 12:02am |
RRover Member Since: 17 May 2021 Location: Sussex Posts: 278 |
Thanks for these tips all. Yes I have been searching and have happened across a few posts almost similar in nature.... Just wanted to be a tad more specific and also some of the closely relevant posts are quite old, and we learn different things as time goes by...
18th May 2021 7:26am |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3744 |
I did what Craig suggested drilled the holed drained the water and resealed, surprisingly (to me at least) the water was getting in though the screw holes on the back not the seams. How do I know I injected (with a syringe) some soapy water and the blew it out with a compressor and watched for the tell tale bubbles. I left the hole as a vent but no water got in through it. Geoff |
18th May 2021 9:54am |
Interesting yet again, ss... I guess you mean the four big Philips screws at rear of light cluster?!? If so, I would not have suspected any water ingress from that area!!! On mine this area is or appears bone dry - whereas the inner side wall seam/join between black body and clear perspex lens, which is hidden when hatch is closed, has damp and moss like similar at car window rubbers during winter?!? Looks like I'm heading towards the tiny drilled hole - so I guess start with 1mm slow drill bit size and increase bit size until water evacuates! Then plug!
18th May 2021 11:57am |
Mine was/is an L405 so might not be the same but I think the rational is the same, get the water out and seal everything Geoff |
18th May 2021 3:47pm |
Wrenched (that lecky connect plug is so damned tight - my nicely manicured nails sod it )) the cluster off yesterday, ready to punch a hole in it at lower edge, but didn't need to, as the water started gushing out (where the heck does it hide?) without the addition of a drilled hole as the clear plastic to dark plastic join/seam (do those four torque screws tighten this join/seal?) had a 2mm gap in it, so ingress-ed water did flow out with ease once unit was tilted.
19th May 2021 9:33am |
When you think all the condensation has gone, seal it in a plastic bag over night, that will show if any is left... Pete
19th May 2021 11:44am |
Gotcha - that makes sense!!! Saw another vid on-line where the cluster (sounds like something existing way out in the deep cosmos ) was put in a corrugated/cardboard box with a section of same material slotted in diagonally and an air-dryer was directed towards the diagonal section so not in direct contact with the cluster and this also seemed to gradually dry the cluster out... Took a few hours though... |
19th May 2021 1:43pm |
This was how much condensation was left inside light cluster after slightly prising join/seam apart with screw driver and letting about an inch to inch and a half of water gush out. Dried off indoors for several days, then sealed with clear silicone to the hatch, and lower section seams edges.
23rd May 2021 4:34pm |
