Home > Technical (L405) > Charging system fault detected
Rufus135
United Kingdom 2018 Range Rover Vogue SE SDV8 Loire Blue
Hi all. Jumped in my ‘68 SD 4.4 today and “charging system fault detected” came up with a picture of a battery. Drove off to find the heated steering wheel and heated seat wouldn’t come on. Assumed significant lack of battery power, so turned around and went home to get into a different car for my 2 hour round trip Monday work journey.
Its due to go down to Taunton LR (from Cheltenham) Friday as a coincidence. . Anyone have experience of this and whether I’m likely to make it to Taunton!!!?
Post #594544 17th May 2021 8:47pm
knwatkins
Do you know what the state of your battery is? If the car had been standing for a while before you jumped in, the battery may have been a bit low. These vehicles sometimes throw spurious errors when the battery voltage is low. Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #594548 17th May 2021 9:21pm
Rufus135
The garage put a new battery in it when I picked it up a month ago. I thought something was strange this weekend when the stop start wasn’t working.
Post #594549 17th May 2021 9:25pm
AnotherMutley
It could be that the Gateway Module needs updating, mine did exactly the same thing. Should still be under manufacturers warranty, call LR Assistance out, they can check the battery and update the module if necessary. I don’t think you’ll have any problems getting to Taunton once on the move but the error may need clearing.
Post #594551 17th May 2021 9:37pm
Rufus135
Sounds like good advice thanks
Post #594552 17th May 2021 9:43pm
