Home > Technical (L322) > TD6 Power Steering Issue
WellDrivenJames
United Kingdom 2004 Range Rover Vogue Td6 Adriatic Blue
I took my dog for a walk yesterday and the car drove fine down to the field, but when I got back in the power steering felt almost lumpy, as you turn the wheel a quarter turn at a time it fluctuates between very heavy and very light. I went to move the car again today and it’s still like this.
When I bought the car back in February we did a full flush of the steering system as it felt a bit heavy ans I’ve done maybe 3,000 miles since. Car is a 2004 TD6 with 144k.
Any suggestions appreciated. Thank you. '04 Adriatic Blue Td6 Vogue
Previous - '96 P38 DSE, '07 D3 HSE, '09 FL2 HSE, '00 FL1 (and many non-LR cars over the years!)
Post #594305 15th May 2021 9:01am
Merchy
There is a 'Heavy steering steering diagnosis help' section in the Wiki part, that may help.
If the problem is intermittent it could be the pump drive belt slipping? Just start with the simplest faults to rule them out.
Post #594309 15th May 2021 9:24am
Pawl
Is it only with the steering wheel in the same rotational positions ?
If yes, it's likely to be a steering column UJ that needs lubricating - eg with a good spray of WD40. Paul,
2006 FFRR TDV8 Vogue 151,000 miles & now sold
Post #594315 15th May 2021 9:53am
WellDrivenJames
Yes it seems to be that way, every 45 degrees or so.
Thank you, I’ll dig out the WD40! '04 Adriatic Blue Td6 Vogue
Post #594317 15th May 2021 9:59am
Jonnys19882
United Kingdom 2005 Range Rover Vogue Td6 Adriatic Blue
My 05 td6 has a similar issue, my local indi told me that it’s the servotronic valve, I haven’t yet fitted it though.
Post #594323 15th May 2021 10:33am
