Home > In Car Electronics (L405) > Dash speaker conector
154JON
United Kingdom 2015 Range Rover Vogue SDV8 Santorini Black
Afternoon i am after the location of the plug that the dash center speakers connect to if anyone would know after upgrading from a 12 speaker system,i am doing a hifi upgrade and i cant find the conector. I currently have the 12 speaker system so no speaker in the dash at the moment but i have the 2 x 8 wire speaker plugs comming from the amp so the speaker wires should be in the dash somewhere, i found the parcel shelf speaker wires close to where the speaker will be located.
Any information would be great,have a good weekend. Thanks
Post #593497 7th May 2021 3:28pm
i dont know but you could have a look in the WM.. ... - .- -.
Post #593503 7th May 2021 4:20pm
154JON
Thanks Stan it will not let me in. Embarassed
Post #593508 7th May 2021 4:44pm
works ok for me but i found this and i hope it helps,
https://www.fullfatrr.com/gallery/albums/u...RATION.pdf ... - .- -.
Post #593510 7th May 2021 4:54pm
154JON
Thanks Stan it says something about user name has to begin with a letter.
Post #593511 7th May 2021 4:57pm
154JON
Thanks for that information stan but it does not show where they tucked the dash center speaker wires that come from the amp because they were not used on my build.
Post #593514 7th May 2021 5:06pm
the only other thing i can find is some wiring diagrams but nothing like what you are looking for...
i'm sure someone will soon come along and know.. ... - .- -.
Post #593516 7th May 2021 5:15pm
Kot
Are you upgrading to 19 speakers?
If so does this help? at least you will know the cable colours (2nd from bottom circuit) Green&Orange and White&Blue
 2018 SE SDV8 4.4 Byron Blue
Post #593531 7th May 2021 7:50pm
154JON
Thanks for the info i found this diagram on this webite which looks helpfull from this website partsouq.com and it seems i need to find an extra part 18B574 as the speaker cable from the amp currently ends at the main loom somewhere behind the the center console . Sad
Post #593587 8th May 2021 10:24am
154JON
I might even already have it as when i lifted the center grill i found a wire that goes to the solar sensor and that cable on the diagram goes to the solar sensor and the speaker so i will have another look as i cant imagine they bothered to fit a differnt cable just because you dont have a center speaker. Exclamation
Post #593589 8th May 2021 10:33am
Kot
Hi
It will be worth a day's subscription to topix and view WS Manual and the other interesting electrical area's
you can view harnesses and download pdf's of 8/19/23 speaker systems.
above is an example of what can be found in the iEWD part of topix documents
Above is EJLR part where you can id connector etc 2018 SE SDV8 4.4 Byron Blue
Post #593600 8th May 2021 12:12pm
