![]() | Home > Technical (L322) > Witter tow bar questions |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4325 ![]() ![]() ![]() |
That looks |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35515 ![]() ![]() |
i wouldnt be happy fitting that... ... - .- -.
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1223 ![]() ![]() ![]() |
I have what looks like the same Witter unit on mine, but the welding on mine looks much better, the weld penetration looks good. Photos not much use from mine as I am just about to de-rust and re-coat it.
Dommo Member Since: 25 Feb 2021 Location: Swindon Posts: 26 ![]() ![]() ![]() |
That's interesting. This is an R32B as well, so it sounds like production methods have changed, unless this one is an exception rather than the norm. It's got a QC label on it though, so Witter are happy with it.
Andygriff73 Member Since: 29 Jul 2018 Location: Ellesmere Port Posts: 68 ![]() ![]() ![]() |
Have you tried Steinhof? Looks a good towbar was going to get a detachable one from Micksgarage.com but they sold out but they are doing a fixed swan neck for £195 plus if register you get a fiver off. A forum member called Anvil fitted the detachable one that I was after he did a cracking write up if you search for it. I managed to get a very good second hand Westfalia in the end I needed it to detach when not in use otherwise I would have bought the Steinhof he said it was good quality. |
Interesting, that's another option.
bigbo Member Since: 07 Jul 2014 Location: Derbyshire Posts: 600 ![]() ![]() ![]() |
I'm surprised no one has mentioned the second hand market, usually plenty around and you get the original Westfalia armature etc. which is much more substantial than the witter in your pictures.
Yes and I had been browsing eBay last night. Given most of them are from scrappers though I'm not going to take a punt until I know which bits I need, in terms of fixings and the such. Basically so that I can identify from photos if I'm going to run into problems during fitting. |
2006 onwards had the exhaust hung from brackets at the back legs of the armature a lot of the second hand Westfalia towbars on eBay are the earlier type the exhaust hangs from the centre of the two back legs don’t know what year your FF is both armatures will fit but you may have to fabricate a couple of brackets if you buy an early towbar to go on a later vehicle. I nearly made the mistake so waited for the right type to come up for sale. |
Cool, that was where I was unsure, thanks.
Dommo even the Westfalia has open cavities if buying secondhand buy the best you can fettle all the surface corrosion off or have it blasted then etch primer it and coat it with hammerite or something similar. The new towbars I would still key it then etch primer it then hammerite it. the manufactures are a little shy with the paint on new towbars as you can see on eBay the condition of some for sale. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8689 ![]() ![]() ![]() |
Personally if you can find one go for a second hand westfalia.
I cut the exhaust brackets off the original arms and then used them with the tow bar but did not weld them in place, just relied on the bolts to hole them in place, so basically no fabrication required. David Range Rover 4.2 Supercharged 2006 Ford Focus EcoBoost 1.5 2017 MG TF 2003 Previous Cars of note Land Rover Discovery 2 Jaguar Mk2 3.8 - Company car MG Midget 1974 - Concours |
