Home > Maintenance & Mods (L322) > Fitting Tow bar
RSW
Fitting Tow bar
So managed to get a tow bar from Ebay for a good price, it needs a claean and a bit of paint but otherwise just what I have been after.
I intend to fit it myself after looking at a few videos it looks like a job I can do
However it arrived without any fixings as per the listing and the rubbers have been cut, is there a kit I can buy or does anyone know the sizes of fixing bolts i need to get?
Thanks
Post #593210 5th May 2021 7:59am
rjff
If it's designed to fit your FullFat, then I would expect you can use the original mounting bolts for the brackets that come off the car. If you want to replace them, then remove and measure up the originals, allowing for any differences in material thickneses. Then speak to Duckworths about it.
As to the rubbers, I can't hrelp on that other than suggesting, that if you know the company who manufactured it, then contact them for ideas. They may also be on a position to provide the kit you need.
HTH
ps if you fill in your car details in your profile it helps others help yoou more easily. AND we're all nosey about what you've got Whistle Cheers
Richard
Gap IIDBT
Post #593248 5th May 2021 11:49am
Andygriff73
Duckworths sell new bolts I think I paid £4 each there are 4 of them then reuse the 8 nuts that hold your bumper bar on I fitted mine on my own with the help of an engine crane set aside a day to do it and use the boiling water method on the rear bumper sides to avoid breaking the lugs loads of info on the forum.
Post #593258 5th May 2021 12:31pm
RSW
Thanks guys, all I need now is a bit of time Rolling with laughter
Post #593327 6th May 2021 7:05am
That doesnt look like a genuine JLR tow bar! Therefore I'm not sure if the bolts that hold the tow eyes on your car will be the same to fit it! Does it have a makers name?
Post #593339 6th May 2021 9:19am
