Home > Maintenance & Mods (L322) > M62 v8 timing chain and guides replacement
Page 1 of 6 123456>
Gsxr1250dave
Iv had an early warning of timing chain guide failure so before it jumps a tooth or breaks up completly junking the engine it's time to get it done.
New parts arrived this week
Timing chain and guide kit
Gasket set
Locking/timing tool kit
Let the fun begin, I will point out due to work I wont be able to do this one my self I find I'm doing 6 day weeks at present so my good mate and mechanic John is going to tackle it for me. Photos to follow.
Post #592706 29th Apr 2021 6:30pm
Bean19844
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
I'll follow this one. Think mines up for renewal again.
Post #592716 29th Apr 2021 7:51pm
Gsxr1250dave
Here are the goodies minus oil filter and oil but I keep them in the garage so no worries about those.
Post #592723 29th Apr 2021 9:59pm
Gsxr1250dave
This is hopefully getting started tomorrow, Thursday had to cancel my guy due to gale force winds and rain this week he Hope's to have it all stripped down, cleaned and inspected by end of play tomorrow then all repaired and assembled Friday.
Post #593265 5th May 2021 2:43pm
Bean19844
If he's doing it that quick, he can def have mine too do...
Post #593277 5th May 2021 5:01pm
knares
Australia 2005 Range Rover Vogue 4.4 V8 Zambezi Silver
O to be that young again RR 2005 4.4 petrol
Any spelling mistakes are the fault of spellchecker
Previous MG J2, CITROEN light 15 x 2 gone unfortunately
Present MERC 180e, RANGE ROVER L322, JAGUAR XJS, MERC 280SE, MG F, JAGUAR S-Type 6v 2003, jaguar s-type 8v 2004, Ford Cougar
Post #593325 6th May 2021 7:39am
BMG
United Kingdom 2002 Range Rover Vogue 4.4 V8 Bonatti Grey
What timing setting kit did you buy ?
Post #593364 6th May 2021 3:13pm
Gsxr1250dave
So day 1 and it's all stripped down. This timing kit is not as good as it looks the deep socket to remove the vanos solinoids wont even go over them and another bit is missing so the cam locking tool jumps off when you go to undo stuff.......
He found my oil leak as well no surprise 1 of the oil seals was Censored out on the left side .
Post #593390 6th May 2021 7:08pm
Bean19844
Looking good mate. How much he charging you to do that
Post #593392 6th May 2021 7:12pm
Gsxr1250dave
Here are a couple of snaps from today
Post #593397 6th May 2021 7:24pm
Gsxr1250dave
No pictures today will try and take some tomorrow. Good progress with the rebuild the guides are in, the right hand small cam chain and tensioner is replaced the left hand tensioner completly broke up but the bolt that holds the toothed wheel to the exhaust cam wont budge.
John found that the left tensioner didnt have a spring in it and the upper tensioner wasnt holding oil so this is pointing to the reason for the failure. Someone has been in there before no BMW part numbers on the tensioners he suspects the camshaft tensioners were replaced at some point but not the chains as there original and stretched. He has done a great job cleaning up the engine and all the parts that cam off.
Packed up for the day to return and have another go at removing said bolt from the exhaust cam. The kit I bought of the bay wasnt the cheapest BUT turns out to be pretty crap. The vanos solinoid deep socket wont go over the solinoid and a clamp is missing that holds the cam locking tool in place at the back of the engine isnt supplied, hence why this is putting up a fight.
It's a big job as we all know the consumerbles on there own are
Gaskets
Oil
Filter
Aircon regass
Coolant
Numerous cleaners etc.
I'm thinking if iv got time tomorrow I mite strip and repaint the cam covers.....
Post #593523 7th May 2021 7:01pm
knares
camshaft bolt
i had the same problem, ended up breaking the tool and the camshaft slipped bending the valves
i cut the chain with an angle grinder and removed the camshaft
i put the camshaft in the vice and with a 3/4 rattle gun, i eventually got it off
i made some stirrups to hold the timing mechanism on the camshafts RR 2005 4.4 petrol
Post #593553 8th May 2021 1:19am
knares
i don't remember the left tensioner having a spring RR 2005 4.4 petrol
Post #593554 8th May 2021 1:22am
Gsxr1250dave
It's odd the left tensioner not having a spring when the one on the right does as they are identical parts.......odd.
He has a very high powered rattle gun which has removed everything else including crankshaft bolts on other engines and this 1.
It get 1 last go tomorrow then the cam shaft is comming out he is very aware that the cam could twist and damage the valves.
So far we have had a 27mm spanner and some very big grips on the cam to prevent this but still it refuses to budge......sometimes these engine just like to put up a fight.
Post #593557 8th May 2021 7:15am
knares
O, i see,
i didnt read it properly, you are talking about the exhaust camshaft chain tensioner
if i remember right, they are not identical but i think they both have a spring RR 2005 4.4 petrol
Post #593602 8th May 2021 1:37pm
Page 1 of 6 123456>
