![]() | Home > Technical (L405) > Whistling sound when cornering |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1214 ![]() ![]() ![]() |
Is this noise only apparent when cornering one way, or cornering both ways. If the noise is loud enough to be heard, then if it is from the air suspension, I would think you would have had other air sus issues by now.
MonkeyMan Member Since: 20 Apr 2021 Location: Ascot Posts: 133 ![]() ![]() ![]() |
Sorry for the delayed reply, been tied up with work. I had a good listen yesterday when driving, it happens when turning both ways, but the sound is only from the left hand side of the car. Its got to go in soon and have a towbar fitted, so the garage will check it out then. |
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 771 ![]() ![]() ![]() |
Welcome to the forum. I had exactly this issue with mine when I bought it last year. See my thread here.
Kev, thats awesome, thanks for sharing that information, makes my life a lot easier with the dealer. |
pherplexed Member Since: 27 Apr 2010 Location: SC, USA Posts: 69 ![]() ![]() |
Thanks for this! I have the side steps and hearing a similar noise when cornering – will check and see if those rubber shrouds are missing. It looks like you had to remove a panel to access those pipes – what's involved? 2021 P525 | Eiger Gray |
Mine is going in to the dealer to have this sorted in about 2 weeks, as well as having a towbar fitted (they listed it as having one, it doesn't, so its on them to fit one). I'll ask whats involved when they get down to this job. |
I had the covers off because I was inspecting the pipes. I can't remember if they need to come off to get the pipes where the shrouds should be located, but taking the cover off is just a simple case of undoing a few fasteners.
