Home > Maintenance & Mods (L405) > Removal of L405 rear seats to accommodate large dogs? |
Bora20 Member Since: 03 Mar 2021 Location: Kamloops, BC Posts: 237 |
@Nasher I would put the lower seat in the garage or somewhere else as not to rip the leather accidentally. The seat base comes out the same for all trim levels, except for the executive seats of course.
20th Apr 2023 2:23pm |
Nasher Member Since: 30 Sep 2009 Location: Down South Posts: 54 |
Thanks Bora20
20th Apr 2023 3:43pm |
The D5 is actually quite large inside, albeit not as boxy as before. This is definitely the better family vehicle size. With three kids, the FFRR does not do the job as well as the D4 did. We don’t travel together often or far. We have a small dog that fits on my wife’s lap. Anything later and a last year D4 or early D5 would be back in the driveway. Dan. 🇨🇦 2013 L405 5.0 SCV8 |
21st Apr 2023 2:16pm |
Thanks Bora, if only I could buy a brand new D4, but I'd be competing for it against many others.
21st Apr 2023 7:14pm |
If I remember correctly there is a harness to disconnect. Super simple. The remainder of the electronics, modules, and wires protected under the seat are then exposed though.
21st Apr 2023 10:31pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16305 |
Nasher, your barking up the wrong tree my friend... You cannot simply remove and replace the rear seats at will. I removed the rear seats and subsequently replaced the seats on the "dog build" and yes we made it a near flat load area for the dogs BUT!!! The seat swabs, frames & wiring needed unbolting/removing then all of the component parts needed storing. The job with care! Took a good full day to strip and another to reassemble. |
21st Apr 2023 11:49pm |
You can remove the lower base portion in minutes though. Everything else could stay to make it “flat” when folded. Definitely not ideal though. 👍 Dan. 🇨🇦 2013 L405 5.0 SCV8 |
21st Apr 2023 11:54pm |
How? The lower base swabs removed just leaves sharp edges steelwork everywhere! And the seats do not fold flat in any way shape or form sir… |
22nd Apr 2023 12:37am |
Oh I know. I don’t think it is a good idea, I just know the seat backs can go “almost” flat. 👍 Dan. 🇨🇦 2013 L405 5.0 SCV8 |
22nd Apr 2023 12:39am |
If you removed the base swabs and then folded the seatbacks I think you would damage the leather on the putruding metalwork...
22nd Apr 2023 1:20am |
Thanks chaps
22nd Apr 2023 10:41am |
Here are some images I took of the “dog car” when we finished the strip out…
22nd Apr 2023 12:35pm |
No offence taken. If you want a completely flat floor, the L405 is not it.
22nd Apr 2023 3:52pm |
A small update on this.
6th Jun 2023 11:30am |
