Home > General > Do your fatty a favour...
The expression "use it or lose it" is very true when you own a fatty...
There are various features that you rarely use but you will want them to work when you need them..
So do your fatty a favour and use them next time you get in it...
Suspension....
Cycle it from standard height to off road, down to access, back to off road and then back to normal...
Gearbox...
Put it into low ratio on a straight bit of road, then, without turning, drive forward 20yds then return to high box, do it a couple of times...
Handbrake
Let the fatty roll forward at tickover and use the handbrake to stop it, do this several times, if you have the later type, just lift the switch and hold it until you stop...
Seats
Move all the seats to their maximum settings both ways.
Windows & Sunroof
If, like me, you never use the sunroof, just try it out a few times, also the rear windows and passenger one if not used much...
This is not a definitive list, just think about the things you rarely use and give them a work out, especially as they have been sat not moving much during lockdown.. And when you can, take it for a good run, and use the upper ends of the rev range to give the engine a good workout...
If anything fails, don't blame me...!!
Thumbs Up Pete
Post #590461 6th Apr 2021 2:29pm
Bl4ckD0g
Netherlands 2010 Range Rover Autobiography 5.0 SC V8 Santorini Black
Nice. And don’t forget the indicators for those models that have bmw engines 🤣
Post #590465 6th Apr 2021 2:38pm
Baltic Blue
Rear screen washer and wiper as well... It never fails to amaze me the number I see on the road where the back screen is caked in gunge . Do they ever use the mirror ??
Post #590467 6th Apr 2021 2:48pm
Bl4ckD0g
It’s because “they all” fail and then squirt the inside of the car Wink
Post #590469 6th Apr 2021 3:03pm
Baltic Blue
They only fail when they get blocked by lack of use. Rolling with laughter
Chicken and egg. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #590471 6th Apr 2021 3:11pm
Bl4ckD0g
Post #590473 6th Apr 2021 3:15pm
Rosco
Re: Do your fatty a favour...
Handbrake
That tickled me Pete, had this one nearly a year and have not used the handbrake once !! maybe should give it a go sometime... Rolling with laughter
Post #590514 6th Apr 2021 7:09pm
Baltic Blue
I am also guilty of not using the hand brake to stop the car,
Perhaps the name is wrong ?... EPB. Electronic Park Brake, suggests its to hold it , not stop it.
Post #590516 6th Apr 2021 7:15pm
Sandyt
I had to rebuild my handbrake as I never used it and the one time I did it went mad and exploded so sound advice Pete Thumbs Up
Post #590517 6th Apr 2021 7:23pm
Rosco
Mike, it is the 'electronic' bit that worries me ! Rolling with laughter
Post #590518 6th Apr 2021 7:25pm
Baltic Blue
Rosco, and me... I have read the workshop manual and getting access to the module is a nightmare, so Pete is right to “work” it.
Post #590520 6th Apr 2021 7:38pm
Mike.
Ehemm some might say the "E" is for Emergency (not electronic) Park Brake sir Thumbs Up
Post #590541 6th Apr 2021 11:16pm
bigbo
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
Ermm the manual says its an Electric Parking Brake
ie no electronics in the parking brake just in the parking brake control module!
Semantics maybe
I just prefer a manual parking brake much more control, more reliable and simpler to maintain.
Oh and easier to do a handbrake turn when you need to impress the girls! Rolling with laughter Rolling with laughter Range Rover 4.2 Supercharged 2006
Ford Focus EcoBoost 1.5 2017
MG TF 2003
Previous Cars of note
Land Rover Discovery 2
Jaguar Mk2 3.8 - Company car
MG Midget 1974 - Concours
Post #590543 7th Apr 2021 12:17am
Baltic Blue
Bow down I bow to your professional opinion Craig, but anything that uses printed circuit boards and integrated circuits to make it work sounds a bit “electronic “ to me. Rolling with laughter
Cheers
Post #590551 7th Apr 2021 7:43am
verydisco
Good post as always Haylands Thumbs Up
I'd add powerfold mirror for early L322s too and rear seat heaters just in case - they hardly ever get used indeed.
Check your spare wheel air pressure too while you do the other 4 and that there is indeed a jack and kit in the boot. l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #590554 7th Apr 2021 9:03am
