Home > Technical (L322) > l322 4.4 tdv8 lost communication with ABS module & SAS
Nic_101
United Kingdom 2011 Range Rover SE TDV8 Java Black
my car simply will not start, has lots of lights up however once the faults are cleared im left with abs pump and sas lost communication faults.
would this point to a bad sas ?
thanks so much for any help
Post #690083 6th Apr 2024 12:00pm
Iwheels
Canada
I have had a similar problem. last year it was a brake light wire that ended up being a faulty wire under the dash on the passenger side (right side here in Canada)
This year I have lost connection with SAS, and I have found a corroded connection under the driver foot rest (sunroof drain can leave water under here if it is plugged, my local pro says)
In the process of repairing that, will post results when i can.
Post #690086 6th Apr 2024 12:41pm
Nic_101
ah okay is that connector one one the right side footwell or left side? thanks
Post #690096 6th Apr 2024 2:56pm
Iwheels
Canada
left side (drivers). turns out they are corroded, but still have continuity.. Rolling Eyes
Post #690130 6th Apr 2024 11:30pm
