![]() | Home > Maintenance & Mods (L322) > Running boards |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35652 ![]() ![]() |
most aftermarket boards [ebay] are patterned on the genuine landrover ones so in theory they should be a straight swop...i would anticipate some fettling though.. ... - .- -.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7912 ![]() ![]() ![]() |
You need to do a search for Side Steps to get tons of info.
Teaspoonasaurous Member Since: 08 Jul 2018 Location: Cambridge Posts: 73 ![]() ![]() ![]() |
Perfect thanks. £300 is steep! |
Good job you don’t want the genuine Land Rover ones then.
Or £986 if you want factory ones to fit yourself.....
t5pete Member Since: 31 Aug 2020 Location: Sheffield Posts: 114 ![]() ![]() ![]() |
I fitted a set of pattern ones to mine I'm sure they were around £170.00.
uzp315 Member Since: 19 Nov 2017 Posts: 428 ![]() |
I bet it is the near side board that collapsed?
4434Morrison Member Since: 02 Mar 2020 Location: Folkestone Posts: 185 ![]() ![]() ![]() |
I bought these recently and fitted them last weekend.
Got this done just in time for MOT. Still failed the MOT quite miserably due to corrosion on the suspension. I'm waiting on the full report.
