Home > Maintenance & Mods (L405) > steering column gaiter
Page 4 of 4 <1234
dez
United Kingdom 2017 Range Rover Vogue SDV6 Santorini Black
Hi All, I’m new to range rovers and this site 😊
I have recently purchased Range Rover vogue 2017 and the steering column gaiter is split and need replacing. Can someone clarify a few things for me please.
1) Is DA3689 – the correct gaiter for my car?
2) Is LR033647 or LR033648 – the correct complete unit?
3) Is 1x LR033655 & 1x QYG500090 – the correct steering column bolts required if I replace 1) or 2) ?
I understand this can be done easily, do you need to do any steering or wheel alignment adjustments afterwards?
Thanks in advance for your help.
Dez
Post #703172 27th Oct 2024 12:53pm
no alignment adjustments needed and it is a 10 minute job, the shaft pushes back up inside the steering column to give you clearance to fit the new bit ... ... - .- -.
Post #703186 27th Oct 2024 3:30pm
dez
Hi Stan, thanks for a quick response. I’ll search for a complete unit, hopefully I should be able to find one on eBay/internet.
Dez
Post #703201 27th Oct 2024 4:45pm
Page 4 of 4 <1234
