Home > General > Do you use the accelerator / deceleration buttons
On the steering wheel when you climb past 30mph , just out of curiosity as i was arsing about with it the other day …. Thumbs Up Laughing
Post #63370 11th May 2011 7:31am
is that on the cruise control mick? ... - .- -.
Post #63374 11th May 2011 7:50am
johnson1
Yes but didn't know you could use it randomly to increase speed!
Post #63376 11th May 2011 8:19am
Fox
I think each press is 1mph up or down. Quite handy in my opinion.
Post #63379 11th May 2011 8:38am
VMPP
Portugal 2007 Range Rover Vogue TDV8 Buckingham Blue
It also serves to set the HDC speed when its active
Post #63384 11th May 2011 9:06am
dan_uk_1984
All the time, I often use it in 30mph areas too so I dont creep above the speed limit.
Post #63385 11th May 2011 9:11am
DMRR
Always - if you hold it down it gently accelerates, although with the adaptive cruise it's even nicer Very Happy Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #63395 11th May 2011 9:35am
dan_uk_1984
Thrasher wrote:
With the adaptive cruise it's even nicer Very Happy
That's the next retrofit!
Post #63397 11th May 2011 9:37am
GregP
United Kingdom 2002 Range Rover HSE Td6 Adriatic Blue
I use mine alittle when cruising down the motorway. Just to make little changes in response to traffic around me. FFRR TD6 HSE
Adriatic Blue with Parchment leather.
Post #63407 11th May 2011 10:21am
Yes when using cruise but thats not that often.
Post #63419 11th May 2011 12:25pm
I had the Adaptive Cruise on my SC RRS, it drove me mad, 'seeing' vehicles in the left lane would cause it to jam on the brakes, especially going through 50mph average speed areas as it would detect the lorry next to me in front and presume I was about to die.
Much prefer cruise that I and only I control. Discovery 4 HSE
Post #63424 11th May 2011 12:53pm
johnson1
The latest version is now much better than that - I haven't had any real false alarms and when it does brake it's very gentle. The LR/RR website promotes that it's now in its Third Generation.
Post #63430 11th May 2011 1:11pm
DMRR
No problems with mine at all either - pretty much perfect. In fact, I use it pretty much 99% of the time on my commute to work and it *saved my RR/me* from a lot of pain when a van in front of me slammed it's anchors on and had *no* brake lights ...... Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #63432 11th May 2011 1:23pm
HUGI
Switzerland 2006 Range Rover Vogue Supercharged Java Black
is it possible to retrofit adaptive cruise controll to 06/06 FFRR??
I dont think soo... Confused
Post #63446 11th May 2011 3:37pm
dan_uk_1984
Anything is possible...
Post #63448 11th May 2011 3:40pm
