Home > Maintenance & Mods (L322) > L322 3.6 tdv8 2010 noise
Landmark
Hi all. Looking to do big service over Easter and was hopeful one of you had had knowledge of niggling noise. Tbh it hasn't got any worse since I purchased and is just so strange. The noise is like a chirp squeek sound and happens immediately after stopping engine. In fact engine has stopped and then noise happens for about 5 seconds after. Thought originally drive belt pulley but noise continues after engine motion has finished. I think it might be common because 3 of the cars that I looked at all done it. Any ideas? Would love to sort when I do service.
Post #588202 20th Mar 2021 9:26pm
Jases4x4
United Kingdom 2010 Range Rover HSE TDV8 Santorini Black
Mine does exactly this, about 5 seconds and its like a rocking squeaking sound, its got to be a pulley or tensioner maybe even fan slowing down. Its done it 5 years i have had the car.
Post #588207 20th Mar 2021 11:25pm
drakes
Mine does this I think it is the turbo actuators or EGR valve or both going through a self check, think they also do it at start up but you can't hear it then over the engine.
I'm sure someone more technical will either confirm this of give us a better explanation 2010 3.6TDV8 Stornoway Grey/ Black interior - gone
Post #588283 21st Mar 2021 5:06pm
Jases4x4
Mines definitely not any of them, this is a bearing noise from fan or a tensioner.
Post #588285 21st Mar 2021 5:13pm
Landmark
Mmm. Originally I was thinking it was idle wheel or tensioner but this noise is after shutting down. Do engine is stationary its like something is free spinning for about 5 secs after engine stops. I'll try and get video.
Post #588333 21st Mar 2021 10:24pm
drakes
This is exactly what mine does the noise is after the engine stops 2010 3.6TDV8 Stornoway Grey/ Black interior - gone
Post #588432 22nd Mar 2021 5:16pm
The only other thing spinning is the fan. Everything else will stop. if it’s the fan spinning it could mean the viscous coupling has gone fubar....
Does it do it when the engine is warm and cold?
It could be the EGR valves cycling back and forth.
If so, It’s normal, nothing to get too worried about. Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #588469 22nd Mar 2021 8:14pm
Jases4x4
Sounds like mine is the fan noise, its like as the fan slows down the noise does around 3 seconds i counted after engine stops. Would a new fan fix this? If so i might get a new fan belt aswell dont think mine has ever been replaced and now on 113,000 on clock.
Post #588470 22nd Mar 2021 8:22pm
briangunn
United Kingdom 2010 Range Rover Vogue SE TDV8 Buckingham Blue
The high pitched hum and squeak squeak squeak sound is the engine management repeatedly cycling the throttle bodies to clear them of any soot deposits..
Post #588489 22nd Mar 2021 10:02pm
Landmark
Ooooo so this is normal then. No further action.
Post #588510 23rd Mar 2021 9:35am
garyRR
This sound is entirely normal. It's the EGR valves and throttle bodies doing their reset cycle (They reset each time you turn the engine off and take the key out)
They only squeak because they're old and the original lubricant has worn off.
Post #589124 26th Mar 2021 10:06pm
Boodle
United Kingdom 2007 Range Rover Vogue TDV8 Santorini Black
Hi all,
This noise has been getting on my nerves too, ive taken a video and uploaded to youtube - is this the same noise as experienced above?
https://youtube.com/shorts/mWUXuPZEjgA?feature=share
Can anything be done about this, its quite embarrassing.
3.6 TDV8 2007
Post #634705 15th Jun 2022 3:20pm
garyRR
Yes, that's exactly it.
It's normal. 2015 Range Rover Autobiography 4.4 SDV8
Post #634706 15th Jun 2022 3:24pm
Boodle
Ok, is it even worth trying to oil them? is it even possible?
Post #634707 15th Jun 2022 3:28pm
garyRR
The throttle bodies are on the front of the intake manifold. To give them a proper clean would involve removing it, which is a pain in the backside, as it usually also involves unplugging various sensors, removing the heatshields and unplugging some of the injectors. Cleaning may only take 30 minutes but removing and re-installing when you haven't done it before can easily take over 3 hours.
You should be able to just emovr the front hoses though and gain some access. You'll have to search the forum to see if anyone has had any success. My throttle bodies on my old 3.6 were clean so, I left them alone. 2015 Range Rover Autobiography 4.4 SDV8
Post #634708 15th Jun 2022 3:35pm
